Re: Farmall 300 kit (Basket case)
Posted by MN Scott on September 11, 2005 at 10:30:53 from (206.9.216.48):
In Reply to: Farmall 300 kit (Basket case) posted by willyz on September 11, 2005 at 05:30:03:
The factory service manual recomneds that you put the pressure plate and disc on the transmission shaft before you join the tractor. When you get it together you bolt the plate to the flywheel by working thru the cover underneth the tractor clutch housing. This works great and you do not risk bending something. I think you should pull it back apart to make sure you did'nt damage something by forcing it together.
Post a Followup
