Re: 806 wide front conversion...Farmall vs. IH
Posted by chadd on September 12, 2005 at 12:52:16 from (155.92.31.115):
In Reply to: 806 wide front conversion...Farmall vs. IH posted by BarryW on September 12, 2005 at 12:23:23:
The International 806 is a different model of 806 than the Farmall. The International was designed for industrial/heavy pulling/low ground clearance work. Because it couldn't have a narrow front, it used an external hydraulic cylinder by the front axle. All International 806's had to have a wide front end, although some were adjustable width and others weren't. They came standard with single hydraulics, a swinging drawbar, and lights mounted in the grill. The Farmall came standard with the tricycle front end with the hydraulic cylinder built into the front casting because an external cylinder wouldn't work. It was taller (used taller rear wheels) and was designed for cultivating and working crops that were taller. It also came standard with dual hydraulics, lights mounted on the sides of the fuel tank cowling and fast hitch, although these options could have been deleted by the purchaser to make the tractor cheaper. The wide front end used on a Farmall 806 had adjustable width and was designed to use the steering system of the tricycle front. Pictures of each are shown below. The top one is our '64 Farmall 806 with the IH front end.
Home
| Forums
Today's Featured Article -
Tire Fluids - by Curtis von Fange. It came as a surprise. The tire on the tractor needed to be pulled off to get to the brakes for service. The tires were blocked, the rear end raised on jacks, the lugs loosened and the tire loosened from the hub. Then, as the big lugged circle of rubber slipped off the last wheel stud it became apparent that there was more there than just an empty tire. Four hundred pounds of rim, tire, and fluid dropped to the ground like a sack of wet cement. Fortunately the installer jumped out of the wa
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
