Re: farmall B cuts out after mowing just minutes
Posted by El Toro on September 13, 2005 at 18:14:17 from (64.12.117.13):
In Reply to: farmall B cuts out after mowing just minutes posted by RCVaughn on September 10, 2005 at 20:28:52:
You need to check your gas flow by loosening the
gas line at the carburetor. Should have a good flow not just a trickle. If flow is good you need to check for blockage at the carburetor inlet. Could have a screen plugged. If that carburetor has a main jet adjusting screw, turn it
ccw to open one full turn. This would allow more gas to your engine under load. Hal
Post a Followup
