Re: 3 pt on IH 444 doesn't work
Posted by JB2 on September 14, 2005 at 13:41:20 from (69.196.154.214):
In Reply to: Re: 3 pt on IH 444 doesn't work posted by Mark Scholten on September 13, 2005 at 19:00:00:
Hi Mark, usually when the 3pt would jump up to the top it was because the depth control lever was not far enough down to the heavy position.
The other thing to check is the spring behind the top link connection. If this spring breaks or the bolt unscrews then the draft control sensing goes crazy. Make sure the draft control sensor is sticking out of the casting about 3/4".
The draft control sensor is a chrome plated rod that sticks out of the hydraulic casting by the right side of the top link bolt.
Good luck
JB2
Post a Followup
