Re: Equipment Auction Advice
Posted by dhermesc on September 16, 2005 at 05:34:39 from (68.110.220.22):
In Reply to: Re: Equipment Auction Advice posted by Nebraska Cowman on September 16, 2005 at 03:12:00:
I'd show up plenty early. Sometimes the owner will "hover" around the equipment (usually the case with better equipment not being passed on by a tractor jockey) to answer questions and to make sure someone doesn't jack with it. Seen more then one case of a tractor having oil shot down the exhaust to make it smoke or a coil/plug wire loosened to make it not start or miss.
They might start it for you so you get a better idea of what your buying. Consignemnt auctions are notorous dumping grounds for problem equipment, examine accordingly.
Post a Followup
