Re: bahlen power steering
Posted by Illinois Boy on September 16, 2005 at 07:33:53 from (12.220.37.158):
In Reply to: bahlen power steering posted by hardcase on September 15, 2005 at 20:02:39:
The Behlen unit runs off the same pump / resevoir as the hyd system. The pressure valve / by pass setup is under the cowl on the opposite side of the valve gang. (usually dist side) and is part of the resevoir - valve gang, opposite the valves.
You"d better get a shop manual if you"re going to tear into it - lots of little pieces. (Don"t ask how I know this...)
Post a Followup
