Hydraulic system still not working
Posted by Mel in OR on September 18, 2005 at 18:48:53 from (67.164.106.40):
I have a 1946 M converted with distributor pump hydraulics. Took the pump in to IH-Case service. The guy said the pump felt good, probably just not primed,(there are no outside leaks, no extra oil in engine pan - I changed oil to check). Put the pump back on and tried priming by applying air pressure to the reservoir, put oil in pump by gravity and turned engine with hand crank (the pump pushed oil out), and tried just bleding air out by loosening a connection on the push side and running engine. Don't know what else to do. Any more ideas would be appreciated. It worked before I took the reservoir out to do work on the clutch a couple of years ago. It has been sitting in my town garage since but now I want to take it to the farm work it. Thanks in advance.
Post a Followup
