Re: Can an 806 pull an 18ft field cultivator?
Posted by james2 on September 19, 2005 at 07:22:15 from (12.2.142.7):
In Reply to: Can an 806 pull an 18ft field cultivator? posted by MichaelNEIowa on September 18, 2005 at 22:48:50:
I sold my 18 ft hydraulic fold IH45 for $150. Shovels needed replacement if covering many acres. Probably sold too cheap, but there isn't any market around here for a smaller field cultivator with limited trash clearance. I tried to pull it one spring with a MM 1050 (dynoed at 118 bhp) in bean stubble, approx 3.5 inches deep, and moved at a snails pace. If you are disking before using the IH45, then no problem pulling it with an 806. Otherwise you will go very slow or just skim the ground. Bought a larger Wilrich which can handle trash much better, and either pull it with the IH 5288 or the IH 4166. Works a lot better!
Post a Followup
