Cub pitman clamp
Posted by matt in pa on September 19, 2005 at 10:12:58 from (12.172.247.101):
Hello.
Anyone know how to rig the pitman clamp on the end of the arm nearest the cutter? I understand that there is supposed to be some kind of spring mechanism in between the two pitman straps for clamping onto the ball end of the cutter. Unfortunately, I do not have the spring and the other piece. Can I run a bolt with a spring through the two straps, or can I still get the right parts from Case? If they are available, does anyone know the cost?
Thanks,
Matt
Post a Followup
