Re: Steering Box Breakdown...Pics in PartsPieces
Posted by TDK on September 19, 2005 at 19:22:54 from (152.163.101.13):
In Reply to: Re: Steering Box Breakdown...Pics in PartsPieces posted by Tweeter on September 18, 2005 at 20:31:36:
There's a snap ring that holds the bottom bearing cup onto shaft. Remove it and shaft should come out. Sorry, Forgot about that!!! The nipple is pressed in. You'll have to heat steering arm to remove it. You can weld it up in place. Either way will work OK. Worn nipple will create play in steering. I've never removed the tube so I'm not sure that they will come out.
Post a Followup
