Re: Belt Pulley for 39H
Posted by Slappy on September 20, 2005 at 07:40:53 from (143.88.85.82):
In Reply to: Belt Pulley for 39H posted by Triker on September 20, 2005 at 06:28:45:
Triker, The leak is due to a faulty seal. These are not hard to replace and your HI dealer can still get them. As to draining the oil, the pulley is splash lubricated by the forward transmission gears - so you change the oil in it every time you change transmission oil. The unit is set up to hold a limited amount of oil. To change the oil in this reservoir and change the leaky seal, you first remove the pulley from the 'wheel' it attaches to. Loosen the bolts (if I remember right 4 of them) on the face of the drive unit and pull the shims, bevel gear, shaft, bearing, seal retainer and wheel out as a unit. A fair bit of oil and probably some water will come out as well. I think (its been a while since I worked on mine) a snap ring holds the works together. If you can avoid it, leave the big Woodruff ket in place. These come out hard and you almost have to destroy them to get them out. They are available but hard to find. If you have to change the bearing, I think the key will have to be removed - maybe yours will come out easier than mine did. I think the seal retainer will come off without removing the key. I'm sorry I don't remember the exact sequence, but the parts manual and common sense will give you all of the details you need. A relatively easy fix. The control is a rod that attaches to an arm on the pulley drive unit and exits the ignition switch plate at the base of your steering support shaft - pull the rod to start the pulley.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
