Re: 454 help
Posted by JB2 on September 21, 2005 at 17:07:08 from (69.196.154.214):
In Reply to: 454 help posted by Galen on September 21, 2005 at 16:23:05:
Hi Galen, again no expierence on gas 454 but lots on Diesel model. If the choke has to be 1/2 closed and it still coughs then the air fuel mixture is to lean. Now this can be caused by many things: 1)lack of fuel flow to carb. 2)carb jets out of adjust. 3)float level to low. 4)vacuum leak around manifold etc. Try the old trick of spraying WD40 around the manifold and carb area while the engine is running. If the engine speeds up then there is a vacuum leak in that area. BECAREFUL NOT TO IGNITE the WD40, have a fire extinquisher nearby. 5)low vacuum from cylinders, caused by valves not closing or worn rings. Quick check is place your slightly spread apart fingers over the air intage of the carb. There should be significant air flow between your fingers. BE CAREFUL NOT TO BURN YOUR FINGERS IF IT COUGHS THROUGH THE CARB WITH HOT GASSES. More indepth test is to compression test each cylinder. Is there any possiblity the carb was assemble incorrectly? About a month ago someone on this site was complaining about similar problem after a carb rebuilt and someone reminded him that the carb venturi can go together in either direction and to turn it around and it solved his problem. Are you positive that the spark plug wires are connected to proper cylinder as per firing order? Good luck JB2
Home
| Forums
Today's Featured Article -
Product Review - by Staff. When we finally checked out the 3000 PSI North Star, the whole story chaned. This unit was equipped with an 11 HP Honda engine with fuel shutoff, adjustable flow and optional syphon degreaser dispenser. It didn't have a pressure release or electric start to facilitate easy starting but according to the instructions, simply pulling on the trigger while cranking was sufficient. This method of starting proved more than adequate and kept the cost down on the unit. It had all the important
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
