Re: Farmall A Heavy Wheel
Posted by Mike@NY on September 22, 2005 at 03:55:42 from (24.58.88.229):
In Reply to: Farmall A Heavy Wheel posted by RETCOL on September 22, 2005 at 02:51:43:
I assume you are speaking of the heavy thick cast center. They are normally placed on the right had side (sitting on the tractor) for balance, as the tractor is offset to the left. I have heard that having the heavy center on the left side can make the tractor more prone to tipping and rolling, but that sometimes they may have been moved over there due to a implement, such as a belly mounted mowing machine (hay bar). Personally, I have mine on the right hand side, always have. Just seems safer to me, and that is the side that always starts spinning on me first. Hope this helps, and I am sure others may jump in as well. Good Luck.
Mike@NY
Post a Followup
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
