Farmall A Heavy Wheel
Posted by RETCOL on September 22, 2005 at 02:51:43 from (64.33.136.147):
I am sure this subject has been covered on the "Board" before but I can't find it. What side of the Farmall A should the heavier wheel be on and why? I have seen it on both sides. I am assuming the left side is correct when I am sitting on the seat.
Post a Followup
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
