Re: Farmall A Heavy Wheel
Posted by Billde on September 22, 2005 at 04:56:05 from (66.249.52.184):
In Reply to: Farmall A Heavy Wheel posted by RETCOL on September 22, 2005 at 02:51:43:
The cast hub belongs on the right side, all the time! If you need more weight on the left for traction or counter-balance ad calcium or a weight.
Post a Followup
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
