Re: IH 706 won't start
Posted by El Toro on September 23, 2005 at 18:29:22 from (152.163.101.13):
In Reply to: IH 706 won't start posted by Terry/South Dakota on September 23, 2005 at 15:50:59:
If you're sure it's getting fuel you should check for fire from your coil wire. Pull the coil wire
from the cap and hold it within 3/16-1/4" of a good ground while someone cranks the engine with
the ignition switch on. If you have no fire there
check for battery voltage at the coil with a volt meter with the ignition switch on. If voltage is present. Replace points and condenser.
If you have good hot spark at coil wire, check for fire at your plugs by removing a plug wire and see if fire will jump from the plug wire to the plug while someone cranks the engine over with ignition switch on. Good fire, pull a plug and hook the wire to the plug and ground the plug on the engine and see if the plug fires. Plugs may need replacing if the plug doesn't fire.
A bad coil or ballast resistor will cause a no start too. Hal
Post a Followup
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
