Re: big plow-small tractor
Posted by Hugh MacKay on September 25, 2005 at 07:59:55 from (209.226.106.94):
In Reply to: big plow-small tractor posted by 504 on September 24, 2005 at 21:11:22:
504: Often this is a good way to make use of and older plow. with many of them you will find damaged or worn beyond use frogs, beams, etc, etc. The semi mount is quite easy to do this with, plus items not damaged or worn give your own parts dept.
Post a Followup
