Re: Super H water Pump Pully Flange
Posted by Haas on September 26, 2005 at 06:02:29 from (12.65.1.242):
In Reply to: Re: Super H water Pump Pully Flange posted by Jon B on September 25, 2005 at 17:32:51:
Seems the thing to do would be to drill a new hole in the hub for the pin after it is pressed back on rather than trying to line up the holes. I would have thought this would be a spring roll pin, but on mine it looks like it is just soft metal.
Post a Followup
