Re: Loose Swartz Wide Front End (for 400D)
Posted by Nat on September 27, 2005 at 06:01:02 from (64.80.110.22):
In Reply to: Loose Swartz Wide Front End (for 400D) posted by Farmall Frank on September 26, 2005 at 16:29:18:
You'll have better luck with SCHWARTZ in your search. The Swartz is from the movie "Spaceballs."
Once the tie rod ends are worn, there's not really much you can do but replace them. Schwartz is still around, so you can still buy the original tie rod ends. WARNING: It won't be cheap, and there is no cheap way out, no cheaper alternative for these tie rod ends.
Post a Followup
