Re: Farmall H carb idle stop screw and idle adjust
Posted by GordoSD on September 28, 2005 at 18:18:49 from (64.68.166.234):
In Reply to: Farmall H carb idle stop screw and idle adjustment posted by John in Ct on September 28, 2005 at 16:03:35:
With the carb on the bench look at the throttle stop screw where it contacts the cam on the end of the shaft. Adjust that so that it is barely touching the cam. Then turn it all the way in counting turns. Then all the way back to the "just touching " point. That is youer minimum setting. Going further out than this is useless.
I wouldn't worry about a little play in the shaft. If you wiggle the shaft and watch the butterfly you will see that nothing really happens there. we're not talking 7000 rpm, 400 hp v8 firebteathers here.
gw
Post a Followup
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
