Re: Farmall A cylinders
Posted by El Toro on September 29, 2005 at 08:20:08 from (205.188.117.73):
In Reply to: Re: Farmall A cylinders posted by jnewark on September 29, 2005 at 07:51:01:
Those old seals are known to leak. They get hard from age and start dripping. You'll need a sleeve puller to pull those sleeves if you decide
to remove them. You can make a puck if you access to a lathe. I have sketch of one if you need it. Hal
PS: With new sleeves and pistons and good maintenance that tractor will be around for another 50 or 60 years.
Post a Followup
