Re: Super H Carb help
Posted by Bob M on September 29, 2005 at 15:38:48 from (69.205.114.112):
In Reply to: Super H Carb help posted by Gary_N_WV on September 29, 2005 at 15:21:55:
Gary - I ran into EXACTLY the same problem with a nephew's 300U. The busted part is the "idle metering jet" (49 798 D 72).
To date he's has had no luck locating a replacement. Further, I'm not sure whether the jet is screwed or pressed into the float bowl casting (the parts catalog just shows the jet in place). So I don't know how to extract the piece that's left in the casting.
A buddy of mine (a jeweler...) has looked at it. Says he thinks can solder the tube back onto the base. So that's gonna be my next step - unless someone else here offers a better solution.
Post a Followup
