Re: electrical charging question on '41 H
Posted by awutay on September 30, 2005 at 18:45:48 from (12.76.156.33):
In Reply to: Re: electrical charging question on '41 H posted by John T on September 18, 2005 at 19:03:40:
John, now I'm really confused. I got the rebuilt generator with the new voltage regulator back onto my 41 H today. The problem persists - its still showing 15 amp discharge when the lights are on. So I took out my voltmeter and started checking things. The BAT terminal on the VR is hot (and obviously the wire from the ammeter to it), but the polarity is reversed! With the negative lead on the BAT terminal and the positive to ground I get just a shade under 6 volts. So I opened up the switch box on the steering column. As far as I can tell, the cables from the VR to the ammeter and from the starter switch to the ammeter are wired correctly (according to my Binder manual). The battery cables also are correctly wired to the battery (If they were reversed the engine probably would crank in reverse but not fire). So, what is backward? The only thing I can think of is to switch the wires on the ammeter. It won't look like the manual, but the current through the ammeter would flow in the opposite direction which would show a charge instead of a discharge Art
Home
| Forums
Today's Featured Article -
Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
