Re: c113 engine boring
Posted by Brian Schmidt on October 01, 2005 at 16:40:28 from (12.215.51.76):
In Reply to: c113 engine boring posted by Charles McNelly III on October 01, 2005 at 12:21:12:
You can not just drop in the 3 1/8" sleeves as I am sure you are aware. You can bore the block to accept the larger OD, but you will also have to re-cut the o-ring grove in the block. The better way to go is to turn down the OD of the sleeves.
Post a Followup
