Re: c113 engine boring
Posted by El Toro on October 01, 2005 at 19:06:10 from (205.188.117.73):
In Reply to: Re: c113 engine boring posted by Brian Schmidt on October 01, 2005 at 16:40:28:
You certainly can just drop in those 3 1/8 sleeves
and pistons without any machining. I've did it
and no machining is required. The same is true with the Super C 123 block going from 3 1/8 to 3 1/4" without any machining. I didn't regroove
the block for the sealing ring, it isn't required.
Hal
Post a Followup
