Re: Farmall B - no spark.
Posted by El Toro on October 04, 2005 at 12:36:52 from (64.12.117.13):
In Reply to: Farmall B - no spark. posted by Dave H (MI) on October 04, 2005 at 11:00:26:
I think your ignition was soaked from that rain storm. You need to inspect the distr for any water as Rusty has suggested. It could have penetrated your plug wires too. Only remove one
wire at a time and see if any water is present.
If there is, dry it with a clean rag or towel and reconnect and repeat this with other plug wires.
Check the coil wire where it connects to that can like devise "your coil" and see if it's wet and where the other end of the wire is connected to the distributor cap. Keep the tractor in full
sunlite it will help with drying. Hal
Post a Followup
