OT - Cement Mixer
Posted by Dave in CT on October 04, 2005 at 17:08:58 from (69.182.86.117):
I picked up a cement mixer at an auction ($10!). It's one of those old beauts with a cast bottom, ring and drive gears and it's not stuck. It's got a spoked cast pulley 16" in diameter with about a 3" wide flat rim. Was this to be driven by a belt from a tractor? I don't have much experience with belt-driven devices but the buzz-saws I've seen have 6" or wider pulleys. This more narrow pulley has thrown me off. The drive shaft the pulley is mounted on is 1.25" in diameter and, if possible, I'd like to drive it with the PTO on my H. I'm imagining a drive shaft coming from the PTO with two universal joints to the drive shaft of the mixer. Does this make sense or am I way off? Anyone done this or should I try to stick with belt-driving it?
The tag on the mixer says 22 RPM. The pulley drives 8.25 turns per 1 revolution of the drum so I'm looking at 181.5 RPM on the drive shaft. I'm imagining running the PTO at a little above idle.
Post a Followup
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
