Re: T/A problems
Posted by Andy in Ohio on October 04, 2005 at 19:29:42 from (206.211.166.17):
In Reply to: T/A problems posted by Levi Keech on October 04, 2005 at 17:43:03:
An experience with my MTA goes like this: Adjust the linkage on the torque. Put tractor in 5th gear and with foot on brakes, let clutch out slowly. If it holds, or tries to stall tractor problem solved. If not check for water in the oil. If so, block up front end for several days and drain front and rear of rear end of tractor. Get all of the contaminated oil out. Replace with Hy Trans oil from Case IH. Try above clutch trick again. If it slips then you need to replace the torque or use as is. Good luck and post back on results. Andy
Post a Followup
