Re: Postive or Negative Ground ?
Posted by Van in AR on October 04, 2005 at 20:58:46 from (216.134.231.237):
In Reply to: Postive or Negative Ground ? posted by iester on October 04, 2005 at 20:37:53:
It was originally POS ground and if you have a POS ground regulator, you should wire it back pos ground. The generater does not care as long as its flashed after installation. Pos ground, the + on the coil goes to the distributor, and the amp meter is wired to read correctly.
Van
Post a Followup
