Re: *sigh*, (from fender-man)
Posted by Slappy on October 05, 2005 at 03:44:07 from (143.88.85.82):
In Reply to: *sigh*, (from fender-man) posted by Pand R Pete on October 04, 2005 at 19:34:16:
Like CNKS, I haven't had the governor off my SA either (yet), but have taken it off my Cub. I believe that matching the timing marks should be similar. That is, you should be able to set the engine at TDC with the crank and the two gear marks CNKS referrs to should be visible. If the marks are on the distributor side, you you should see them when remove the distributor. Either way, if you are careful you can aline the marks with the proper tooth on the govenor gear. The gears are beveled so thake that into account. Again, there may be something about the A tractors that I am not considering, hopfully others will correct me if I'm off base here.
Post a Followup
Today's Featured Article - History of the Cockshutt Tractor - by Danny Bowes (Dsl). The son of a very successful Toronto and Brantford, Ontario merchant, and himself quite an entreprenuer, James G. Cockshutt opened a business called the Brantford Plow Works in 1877. In 1882, the business was incorporated to become the Cockshutt Plow Company. Along with quality built equipment, expedious demand and expansion made Cockshutt Plow Works the leader in the tillage tools sector of the farm equipment industry by the 1920's. ... [Read Article]
