Re: M farmall Starting Problems
Posted by Janicholson on October 05, 2005 at 06:48:28 from (199.17.6.175):
In Reply to: M farmall Starting Problems posted by Josh Johnson on October 04, 2005 at 18:52:16:
First item: is it a mag or dist./coil If it is a mag and the mag was partially disassembled while on the tractor, then the mag may get out of time internally. If it is Dist./coil ignition, turning it with the cap off cannot possibly cause timing changes. there is nothing changing. The following assumes Dist./coil ign., and that the distributor has not been pulled out. Set the points by turning the engine till the point rubbing block is on the very top of one of the lobes of the point cam. (.020) As described put the engine on #1 tdc (front cyl) and align the crank timing marks. With ign sw off, put an ohm meter between ground and the distributor terminal (nut and insulator) that gos to the coil. With the dist. mount bolts just loose enough to turn the dist. housing, rotate the dist. both ways. You will note the ohm meter changing from zero ohms to open circuit (full scale change). The points are opening and closing. Tighten the dist. retaining bolts just at that point when the meter changes to open circuit (infinite ohms). This sets the points to break at the exact moment the timing (on the crank) calls for it. The rotor will now be pointing toward #1 cyl (no matter where it is pointing on the "clock" __note this position in your head. Place the rotor and cap on the dist. Note there may be a plastic dust partition under rotor. Poke the #1 wire in the noted hole, then #3 in the next hole in the direction of rotation, then #4, then #2. Start the tractor (in neutral) and enjoy. Good luck JimN
Home
| Forums
Today's Featured Article -
Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
