M farmall Starting Problems
Posted by Josh Johnson on October 04, 2005 at 18:52:16 from (24.27.179.108):
I have a M Farmall that will not start. When you turn the engine over it will only backfire through the carburetor. There is spark to the plugs and fuel is getting to the carb. What do I do?
Post a Followup
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
