Re: Bout hadit with E-bay
Posted by RustyFarmall on October 06, 2005 at 06:08:38 from (216.248.75.177):
In Reply to: Bout hadit with E-bay posted by Sloroll on October 06, 2005 at 04:37:17:
Most likely the bid just didn't go high enough to satisfy the seller, so he just ended the auction. If the seller wanted a certain amount, he should have put a reserve on the auction. That way everybody knows what they must do to win the auction, and if the reserve is too high, the item doesn't sell, plain and simple.
Post a Followup
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
