Re: What would you do? SA oil pump...
Posted by Janicholson on October 07, 2005 at 15:46:02 from (66.173.50.180):
In Reply to: Re: What would you do? SA oil pump... posted by MagMan on October 07, 2005 at 15:29:42:
If you know someone with a machine shop, it would take almost no time to surface grind the plate to flat. Hand polishing on a flat is ok, but I prefer a K.O.Lee grinder and 5 minutes.
The way it is is probably OK, but why not tighten the system as much as possible.
JimN
Post a Followup
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
