Re: No Fire
Posted by El Toro on October 08, 2005 at 16:13:06 from (205.188.117.73):
In Reply to: No Fire posted by Jeffnofirefarmall on October 08, 2005 at 14:57:03:
You need to check to make sure your mag isn't being grounded out. This is how the engine is shutdown by grounding out the mag. With a distributor the ignition switch kills the battery voltage to the ignition components. There may be switch to ground out the mag, I had an A, but it
had a distributor. The coil may be weak too.
The MagMan that posts on here rebuilds IH mags.
Hal
Post a Followup
