Re: Generator Problems '45 Farmall A
Posted by John T on October 08, 2005 at 16:22:39 from (66.244.90.98):
In Reply to: Generator Problems '45 Farmall A posted by thynes on October 08, 2005 at 14:09:53:
Thynes, Ive not had all that much Farmall experience but I can tell ya this. Your First question........ If that "device" you call a cutout relay has 3 terminals labeled BAT and GEN and FLD,,,,,,,,sounds to me like its a full fledged Voltage Regulator instead of only a 2 wire Cutout Relay. A Cutout Relay has but 2 terminals, labeled BAT and GEN. On those systems, the Generators Field post wired up to the light switch where it received a dead ground for High Charge but was grounded through a resistor for Low Charge. They DO NOT HAVE ANY CONNECTION TO OR FOR THE GENERATORS FIELD POST. On Voltage Regulator Systems, they Wired BAT to the ammeters load side,,,,,,,GEN (or ARM) to the Gens Armature post,,,,,and FLD on the VR wired to the Gens Field post AND NOT UP TO THE LIGHT SWITCH. Its possile they got converted over the years from a cutout relay to a VR ?????? If you have a good working Gen and a good VR, I would use the VR instead of a light switch control !!!!!!!!! i.e. wire the 3 terminals as stated above for a VR, NO WIRES TO THE LIGHT SWITCH A Cutout Relay has but one coil/relay,,,,,,,a VR has 2 or 3 coil/relays depending on if it has current and voltage regulation. Why dont you take a good look at the labels on the terminals on the device you have and its insides again??? Second Question
If there were load on the Generators and there was no voltage or current regulation, the voltage could and should continually increase as the Gen turned faster and even pop a 12 volt light. Post back your findings and any questions Let me know if you need my complete Troubleshooting Procedure for non charging. Good Luck n God Bless John T
Home
| Forums
Today's Featured Article -
An AC Model M Crawler - by Anthony West. Neil Atkins is a man in his late thirties, a mild and patient character who talks fondly of his farming heritage. He farms around a hundred and fifty acres of arable land, in a village called Southam, located just outside Leamington Spa in Warwickshire. The soil is a rich dark brown and is well looked after. unlike some areas in the midlands it is also fairly flat, broken only by hedgerows and the occasional valley and brook. A copse of wildbreaking silver birch and oak trees surround the top si
... [Read Article]
Latest Ad:
Variable pulley for case 1530 skid loader
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
