Generator Problems '45 Farmall A
Posted by thynes on October 08, 2005 at 14:09:53 from (66.189.90.38):
I have a '45 Farmall A with messed up non-original wires. When I got the tractor the charging system did not work, and the wires were a cobbled up mess. Since they were goofed with, I don't have any confidence that the wires are correct.
I believe that I have a cutout relay, as it only has one coil. It has 3 terminals: gen, F, and Bat. I have found several wiring diagrams to help me out, but I still have some questions.
Question 1: On the cutout relay do I connect the "F" terminal to anything? The schematics I have show this with no connection. Inside the cutout relay the "F" terminal is connected to a resisitor. This resistor is connected to the ground of the cutout relay. It seems this "F" terminal is a redundant equilavent of the field resistor in the switch box, is this corrct? If that is correct then do I leave the "F" terminal unused?
Question 2: I had the tractor running for a while with nothing connected to the generator and noticed it was hot. I checked for voltage at, I think at the "A" terminal, and it was putting out voltage. When I reved the engine to full speed, the voltage went to about 30 volts. This voltage promptly burned out my 12v test bulb! Is this normal, or is there an internal short in the generator that is allowing output with no wires attached?
Regards,
Tim
Post a Followup
Today's Featured Article - An AC Model M Crawler - by Anthony West. Neil Atkins is a man in his late thirties, a mild and patient character who talks fondly of his farming heritage. He farms around a hundred and fifty acres of arable land, in a village called Southam, located just outside Leamington Spa in Warwickshire. The soil is a rich dark brown and is well looked after. unlike some areas in the midlands it is also fairly flat, broken only by hedgerows and the occasional valley and brook. A copse of wildbreaking silver birch and oak trees surround the top si ... [Read Article]
Latest Ad: Variable pulley for case 1530 skid loader [More Ads]
