Re: Novice needs help with a Farmall H.
Posted by brainerd dave on October 12, 2005 at 10:04:40 from (148.78.247.10):
In Reply to: Novice needs help with a Farmall H. posted by Brad from PA on October 12, 2005 at 09:53:13:
Put a charger on the battery overnight just the same. Lights don't draw much power to work. Your starter does. Check your cable connections, and like Jay says, easy on the choke.
Post a Followup
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
