Re: Novice needs help with a Farmall H.
Posted by brainerd dave on October 12, 2005 at 10:13:27 from (148.78.247.10):
In Reply to: Re: Novice needs help with a Farmall H. posted by brainerd dave on October 12, 2005 at 10:04:40:
You may have also hit a flat spot on your starter armature. I've had occasional luck "burping" the starter to try and bump it off the dead spot, but more often than not, I've had to rebuild the starter.
Post a Followup
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
