Re: Super W4 electrical problems, Lots of sparks..
Posted by Janicholson on October 12, 2005 at 15:02:42 from (199.17.6.175):
In Reply to: Super W4 electrical problems, Lots of sparks.... posted by EddyJ on October 12, 2005 at 14:10:11:
The issue is a failed ground. To solve it the following may provide insight. The battery ground strap comming from the negative terminal should be attached to the clutch housing (torque tube). There are several threaded locations suitable for this attachment. The cable end terminal should have a 3/8" hole in it. Use a tap and clean the threads in the hole in the housing. Use 100 grit paper and clean the surface of the housing where the ground strap will attach till it is bright cast iron. Use a new bolt (short enough to not bottom in the casting) with a new flat washer under the head to bolt the cable to the casting. The starting energy now has only a short path to get to the starter motor. (I'll bet it is now grounded to the steering wheel brackets, and they are not adequately grounded, because of paint or rust or unknown gaskets). Poor ground will also cause charging problems. Though this may eliminate the sparking, other issues may be causing the charging problem. One step at a time. Keep us informed on the forum so we can gain from the solution. JimN
Home
| Forums
Today's Featured Article -
Check Your Coolant - by Bill Radford. Great tips on how and when to check the coolant in your tractor.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
