Re: Novice needs help with a Farmall H.
Posted by Janicholson on October 12, 2005 at 15:13:16 from (199.17.6.175):
In Reply to: Re: Novice needs help with a Farmall H. posted by jimmer on October 12, 2005 at 11:07:01:
The jambed starter idea is sound advice. This is a continuing saga. Many many IH Farmalls do it. Putting it in High gear and violently rocking the rear wheel often frees the starter without wrenches.
See archives for advice on stuck starters.
JimN
Post a Followup
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
