Re: Novice needs help with a Farmall H.
Posted by jimmer on October 12, 2005 at 11:07:01 from (66.170.62.194):
In Reply to: Re: Novice needs help with a Farmall H. posted by Jay (ND) on October 12, 2005 at 09:56:30:
Make sure the gas shut off is opened all the way. Close completely by turning clockwise. Open counter clockwise. It will be located underneath the middle of the gas tank. Pull on the choke rod & make sure that the ignition switch is pulled out. If you have a hand crank, you can use it if battery is weak but genny must work well to supply voltage to dist.
BTW - The H production was stopped in 1953. So it is older than you give credit...
Post a Followup
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
