Re: 806 Range Gears
Posted by Randy in NE on October 13, 2005 at 03:58:57 from (204.124.192.91):
In Reply to: 806 Range Gears posted by Rocko1 on October 12, 2005 at 19:42:16:
I would suggest checking the shifter linkages between the shifter handle and the transmission case. These can get some wear on them. Individually the linkages don't look that bad but add them together and you may have enough slop to keep it from going into gear. I know a guy with a pulling 1206 that had trouble getting it into the high side. He built up the linkages and now it shifts as good as new. I would check this before I split it.
Post a Followup
