Re: 806 brakes
Posted by the tractor vet on October 15, 2005 at 06:50:17 from (4.124.95.221):
In Reply to: 806 brakes posted by retier on October 15, 2005 at 05:18:27:
Well before i get going this morning i'll try on this one , There are several places to look . (1) first Bleed the brakes , (2) what shape are the brakes in ??? you could have stuck adjusters and the pistons are cocked , It could be a stuck check valve (there are two) one on top of the MCV under the fitting on the crossover line and also on the brake valve , Flow divider sticking low pump output , sticking sump check valve, that one is in the lower righ hand corner behind the MCV , and on some rare occasions the brake valve it's self. Here again it would be nice if i could see it and check it myself.
Post a Followup
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
