Re: 826 Hydro steering problem
Posted by the tractor vet on October 15, 2005 at 17:10:32 from (4.124.76.166):
In Reply to: Re: 826 Hydro steering problem posted by David Riedel on October 15, 2005 at 08:27:16:
It is why down in the rear housing and the only way to get to it is remove the whole top of the rear end , not a bad job if ya got a good cherry picker a few lines to remore on some models also ya should remoe the top link plate so you can see the draft sencening linkage look before ya remove that way ya know what side the arm must go on. Now one other thought that you may be money ahead if ya just took it in to a Case IH dealer and have the MCV flowrated and IF THEY HAVE THE NEW SERVICE TOOL to take the two reading on the pressure on the MCV . THe more i think about it it still comes back to either low pump flow or a sticking or weak flow divider spring.
Post a Followup
