Re: 826 Hydro steering problem
Posted by David Riedel on October 16, 2005 at 11:41:01 from (4.224.186.85):
In Reply to: Re: 826 Hydro steering problem posted by the tractor vet on October 15, 2005 at 17:10:32:
Hello again. Went through the steering control valve again.
Everything looks great, and slides well. I don't think it's the
problem. I think the roll pin over the steel ball check valve,
actually pushes in on it a little, not sure. I tried shimming the
flow divider a little to stiffen the spring, with no results. I'm
starting to fear that I'll never troubleshoot this problem. I'm
starting to lean towards a pump problem too, except two things
really bug me. First, the steering worked perfectly before I had it
serviced (local IH dealer) to fix a problem with no power in the
hydro (turned out to be the seal in the foot n inch valve). I'm
surprised they let the tractor out of the shop with the problem,
which they blamed me for for some reason, saying I let the fluid
get too dirty. Secondly, just recently, I removed the MCV,
cleaned around a little (didn't remove the pump from the MCV)
reinstalled it and the steering worked perfectly for around six
start ups. On the seventh startup, whamo, right back to the
same problem. Keep the good ideas comming. Thanks Dave
Post a Followup
