Re: FARMALL BN DRIVE TRAIN NOISE
Posted by Dave BN. on October 16, 2005 at 08:12:19 from (205.188.117.73):
In Reply to: FARMALL BN DRIVE TRAIN NOISE posted by PA. FARMER JOHN on October 14, 2005 at 20:53:07:
Sorry for the late post. I Don't get to read the board every day. Your problem is most likely the oil slinger gear. It is towards the rear of the lower shaft in the transmission. It is fairly large diameter and quite thin and is made of die cast and is very easy to spot as it looks different than the other gears. It is ment to provide oil to the bearings when the tractor is running but not moving, like when using the belt pully. I would replace the transmission oil (90W) first to see if that quiets it down. The fill hole is by the shifting lever and the drain hole is at the bottom rear on the right. These are flat pipe plugs with square holes that no wrench will fit. I made a tool to remove them by grinding a square end on a big allen bolt. If you have a belt pulley there is a drain in the bottom of that housing. It is a small pipe plug. There is a fill on the top also I believe. It takes a small amount, 1/2 cup maybe. The tranny takes 5 quarts I think and the level check is on the left side of the transmission behind the brake shaft if I remember right. Fill the transmission to this level and do not overfill or your oil seals will most likely leak. I flush my gear boxs out when I change fluid. For example you could pour some "cheap" motor oil in the fill hole and let it drain out the bottom. See what it looks like and repeat if it looks really bad. If you need to replace that oil slinger gear you'll have to repost as that is quite involved. Good Luck. Dave.
Home
| Forums
Today's Featured Article -
Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
