Re: Bearing number for differental shaft for A
Posted by CNKS on October 16, 2005 at 09:06:41 from (204.249.178.138):
In Reply to: Bearing number for differental shaft for A posted by Tiny TIm on October 16, 2005 at 07:59:02:
There are several bearings. The one called the differential bearing is the one that fits in the bearing retainer that bolts directly into the transmisson/differential housing. I.E. you have to remove the wheel and the drop axle housing to get to it. Number is ST 202. Any bearing place can cross it. Cost is likely $50-$100. The lower axle shaft itself goes thru inner and outer bearings. The inner is ST 205 A. Outer is ST 278. The differential shaft (upper shaft) bearing is ST 239. These are SUPER A numbers, I imagine the A numbers are the same, double check first. If you do not have a parts book, you need to look at the diagrams on A CIH dealers computer to make sure you get the right bearing.
Post a Followup
