Super C - taking steering mechanism apart?
Posted by leon on October 18, 2005 at 17:29:10 from (12.219.23.183):
OK, I have the vertical steering shaft with worm
wheel assembly out of the front housing and
have removed the through bolt, but how do I
get the shaft out of the assembly? Shouldn't I
be able to support the lower bearing cover and
press/beat the shaft down through the
assembly? It sure is tight! Will this removal
method damage the lower bearing?
Post a Followup
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
