Re: SC clutch problems - Continued, part 3:
Posted by AC Hodges on October 18, 2005 at 21:12:29 from (4.131.95.31):
In Reply to: SC clutch problems - Continued, part 3: posted by skycarp on October 18, 2005 at 19:49:21:
If you compare the the tubes where the rockshaft on the bottom rear is connected you will see a difference in the linkage. You will have to use the C linkage with the internal adjustment. It will connect to the Super C pedal but may be at the extreem of available adjustment. Might have a problem with the linkage between the pedal and the rockshaft,(They are different). The hydraulic will be OK both types were used on the Super-C. Other than that I think it would work. Don't know where you are but I have a extra SC torque tube you could have cheap. Craig
Post a Followup
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
